Author Topic: class diagram default details  (Read 4201 times)
bkate
« on: January 10, 2006, 08:07:12 am »
Is there a way to configure my settings (or the EABase) to show full parameter details on all new auto-generated class diagrams? I import a source directory and create class diagrams, but I have to manually change the details and re-layout each one, very annoying...
- Bryan
Re: class diagram default details
« Reply #1 on: January 10, 2006, 01:18:06 pm »
Create a new package. (Call it 'Templates' or something similar)
Create a class diagram in that package.
Set the options for the diagram that you want saved.
Select Settings | Template Package.
Select your package from above.
Alternatively, on the directory import dialog click the 'New Diagram Options' button.  It gives options to set on all diagrams created by a source import.
bkate
« Reply #2 on: January 11, 2006, 04:49:11 am »
I do not see the 'New Diagram Options' button when I do
Project | Source Code Engineering | Import Source Directory.
Where you referring to version 6 (I am running EA 5), or am I not doing it correctly?
- Bryan
« Reply #3 on: January 11, 2006, 11:26:58 am »
This is new with EA 6.0
« Reply #4 on: January 11, 2006, 01:18:21 pm »
Yes, I was referring to version 6, and the button is new.  You can still set up a template package, but the menu command will be at Project | Set Element Template Package.
Graham_Moir
« Reply #5 on: January 12, 2006, 05:02:24 am »
Is setting the "Template package" also then supposed to provide a set of defaults for packages created manually within the model ?   Doesn't seem to do this, but as you have to select a default template from the current project hierarchy anyway it would be great if it did.
Or have I missed something ?
« Reply #6 on: January 12, 2006, 01:13:44 pm »
It doesn't appear to.  As far as I know it's only intended to work for elements and diagrams.
