Author Topic: Export and import diagrams within EA  (Read 5240 times)
ufechner
  • I love YaBB 1 Gold!
« on: February 22, 2006, 07:53:49 am »
I have the following problem:
I need to move a (state-) diagram from one EA projekt to another one.
I have the diagram and all its elements in one package, so I export it with xmi and import it into the second projekt, stripping the GUID's (as there is a second version of this diagram already there).
Now all the connections between the states are messed up.
(This means: Direct lines instead of the well thought connections
with many manuell adjustments, that I made before.)
Why?
Is there a way, to prevent this?
I need hours to get it looking the way, it did before.
Regards:
Uwe Fechner
Re: Export and import diagrams within EA
« Reply #1 on: February 22, 2006, 10:23:44 am »
Uwe,
Which version and build of EA are you using? And what are your XMI settings?
« Reply #2 on: February 22, 2006, 10:35:34 am »
Hi again Uwe,
I just ran a quick test. Worked like a charm!
Here's what I did:
  • In the EA Options dialog under XML Specifications, I checked Export Images and Export Diagrams.
  • Ensured that I checked the Generate Diagram Images in the XMI Export dialog.
  • Completed the Import as you describe.
My diagram came through just fine, without disturbing the prior version I created in the target model.
hth,
