Author Topic: Importing DB Schema from Oracle  (Read 4922 times)
pushtak7
« on: March 06, 2006, 12:18:47 pm »
Maybe someone can help with this:
When I import a DB schema from Oracle, the table comments are truncated to include only about the first 80 characters.  Anyone know how to fix this??
Thanks.
hd
Re: Importing DB Schema from Oracle
« Reply #1 on: March 06, 2006, 02:19:22 pm »
Can you provide more details - EA version/build, Oracle version?
EA build 788 successfully imports > 80 char table comments from Oracle 9i (9.0.1.0.1) using ODBC driver 9.00.11.00.
pushtak7
« Reply #2 on: March 06, 2006, 03:49:25 pm »
EA version/build 6.0.778
Oracle 10g 10.1.0.2.0
Importing with Microsoft ODBC for Oracle version 2.575.1117.00 data 8/4/2004 - this is the only ODBC driver that I could get to work.
Thanks.
hd
« Reply #3 on: March 06, 2006, 06:03:18 pm »
Using build 778, Oracle 10.2.0.1.0 and Oracle ODBC Driver 9.00.11.00 works for me.
(The Microsoft ODBC Driver for Oracle will not work).
If you have any further problems, submit a bug report directly to Sparx.
mikewhit
  • Accessing ....
« Reply #4 on: March 07, 2006, 01:05:46 am »
I presume this problem has been notified to Microsoft ?
People tend to assume that MS stuff works, and if not it must be your fault !
« Reply #5 on: March 07, 2006, 01:39:25 am »
Mike,
do you think, MS will respect bug reports? My feeling is that you can tell it to the next hydrant and it will help more...
« Reply #6 on: March 07, 2006, 02:58:22 am »
Mike,
Thomas,
You undersell Microsoft.  I reported a bug in MS Word v4 (which had been there since MS Word v1) and they started to fix it in MS Word v10  (Word 2000).  ;D
« Reply #7 on: March 07, 2006, 03:57:59 am »
Paolo,
I could swear you haven't told it your next hydrant. Else it would have been fixed already ;)
pushtak7
« Reply #8 on: March 07, 2006, 06:08:32 am »
Thanks for the suggestion.
My problem with the Oracle ODBC driver is that when I try to configure a user DSN I get an error: Unable to connect. SQLState=IM004.
I've scoured the boards, checked my environment variables (PATH, TNS_ADMIN), reinstalled the drivers, etc.  Nothing seems to help.  Any insights from the all-wise gurus would be appreciated.
« Reply #9 on: March 07, 2006, 12:31:11 pm »
Do you receive that "Unable to connect" only with EA or generally when e.g. trying to import data from Excel.
Btw.: I'm neither an Oracle nor another Guru, just a frequent poster
« Reply #10 on: March 07, 2006, 12:32:02 pm »
pushtak7
« Reply #11 on: March 07, 2006, 03:01:33 pm »
Well, I've succeeded getting the driver to work and the comments seem to transfer ok.
Here is another question: All table columns that are of type NUMBER import with precision and scale set to 0.  Any way to fix this?
Thanks.
