Author Topic: Removing overloaded operation in transformation  (Read 2241 times)
alon.novy
« on: March 29, 2006, 12:43:59 am »
Hi All
I have created a transform that is working ok and is pretty similar to the NUnit transform.  The only prob is that where a class has an overloaded operation, I want the transform to generate a single operation, no matter how many overloads exist for the original operation.
How do I do that?
Thank you
Alon
Re: Removing overloaded operation in transformatio
« Reply #1 on: March 29, 2006, 02:16:29 pm »
The code templates don't have any mechanism for finding what you've already seen or generated, so the best approach I can think of at the moment is to use an addin call from the template. (EXEC_ADD_IN function macro.)
One possible way to use this would be a call at the start of your operation template to allow generation.
Untested
$gen=%EXEC_ADD_IN("MyAddin", "AllowOperationGeneration", classGUID, opName)%
%if $gen!="T"%
%endTemplate%
... Rest of template
That should get you going.
« Last Edit: March 29, 2006, 02:16:52 pm by simonm »
