Author Topic: scripting within EA  (Read 2482 times)
xkrystof
scripting within EA
« on: November 29, 2007, 12:49:01 am »
I created script (*.wsc), I registered it as an compoment and it is possible to run it as Add-Inn.
However, every time when I change the code of the script, I need to close EA and open it, to run script with altered code. It is really time consuming ...
Is there any way for scripting in EA, when I can have EA opened for the all time, change the code and run it?
thanks
Jan
Re: scripting within EA
« Reply #1 on: November 29, 2007, 01:08:42 am »
Yes,if you use Perl. I invoke a Perl script that offers all Perl scripts in a certain directory in the context menu. Then I can change these aty any time as they will be executed dynamically.
xkrystof
« Reply #2 on: November 29, 2007, 01:27:16 am »
thanks for the hint, ... but still
- which context menu do u mean - how can I run a perl script - from where?
- how does Perl will know about EA api?
- could u attach an perl example?
thank s is advance ..
« Last Edit: November 29, 2007, 01:35:11 am by xkrystof »
« Reply #3 on: November 29, 2007, 02:37:15 am »
You can look here http://www.eausergroup.org/
I posted some Perl/WSH coding some years ago (always promising to update/transfer it to the Wiki, but really no time
