Author Topic: Is it possible to hide operation parameters?  (Read 8550 times)
Physicus
« on: March 16, 2006, 06:41:29 am »
in a class diagram: is it possible to hide the parameters of an operation for a single class element?
Thanks and greetings,
Physicus.
Re: Is it possible to hide operation parameters?
« Reply #1 on: March 16, 2006, 07:16:02 am »
Yes, there is:
Open diagram properties. On the right hand side about 1/3 od the way down you will find a "Show Parameter Detail" dropdown. The default is Type Only. All four combinations of yes/no for parameter type and name are available (i.e. you can select "None").
I've not found any such setting at the 'global' level, nor have I found something to do this for attributes (vs. operations). However, your requirement regarding parameters on a per-diagram level should be covered just fine.
Physicus
« Reply #2 on: March 16, 2006, 08:24:43 pm »
No, there is not!
thanks for your answer, but my question belonged to a single class element instead of the whole diagram. In other words: I want to do this only for one class (concerning my situation, I actually need it for one single operation within one class, but I didn't venture to ask for this). Therefore, I need such a drop down box for the element visibilities instead of diagram visibilities.
Any ideas?
« Reply #3 on: March 17, 2006, 01:56:25 am »
Nothing else except the feature visibility and the above.
« Reply #4 on: March 17, 2006, 05:22:09 am »
Of course you could always make this particular element private, and then set the display to exclude these. This could be a problem if you need to display other private elements. Since I don't know the context of your problem (why you need to hide this particular feature) I cannot suggest anything else.
« Reply #5 on: March 17, 2006, 12:43:55 pm »
David, that does not help in hiding parameters, though.
« Reply #6 on: March 19, 2006, 05:00:45 am »
True Thomas, but it might go a ways towards what Physicus seems to be saying.
By making features I don't want show (on a given diagram) private, setting the diagram not to show private features, hiding visibility indicators (for a clean look) and setting parameter detail to none (or whatever), I can highlight those features, including operations that I want to show. Parameter details reflect the setting, and can be name or type only, or hidden...
The downside remains that you are 'artifically' setting visibility. When your modelling gets much past the brainstorming level this is likely to come back and bite you in some fashion.
Still, the ability to present a (visually) simple model at an overview level is a very useful feature. I've requested the ability to turn off all display adornments for attributes (i.e. show just the name without any pucntuation without having to erase the data type etc. but have not yet had any positive response from Sparx. Sigh...
« Reply #7 on: March 19, 2006, 09:58:26 am »
I remember. There have been several similar requests about displaying element adornments. Would really be nice to have something to group requests, give votes and to see how Sparx reacts on those (being another unheard request too :()
SF_lt
  • The Truth Is Out There
« Reply #8 on: March 20, 2006, 10:49:53 am »
Some time ago I have requested feature to manually show/hide particular class methods and attributes by extending visibility feature window
EA 6.1 and later builds still don't have this ;)
registertm everything to SparX
« Reply #9 on: March 20, 2006, 01:03:36 pm »
One of the real big issues for me is, that there is no way to correctly file a request. Sparxians listen to what the users are saying, which is excellent. But unfortunately there's too much noise so they miss some really important threads. A public roadmap for bug fixes and forthcoming features would cure most of these remedies. A voting mechanism would be brilliant.
« Reply #10 on: March 20, 2006, 03:00:28 pm »
Seconded
« Reply #11 on: March 20, 2006, 03:15:48 pm »
And how - me too!
« Reply #12 on: March 20, 2006, 03:39:48 pm »
From the EA main menu "Help | On-Line Resources | Request-a-Feature". These don't get read once and thrown away - they stay on file and are a searchable resource that we actually refer to on a regular basis. By all means use the Requests forum here, but send in a feature request as well.
« Reply #13 on: March 20, 2006, 03:48:11 pm »
KP,
It was the second half of Thomas' post we were voting for!  Will Sparxians be addressing those issues?
nara_c
« Reply #14 on: April 26, 2006, 09:46:24 pm »
No, there is not!
Any ideas?
Physicus, it is possible to hide Attributes or Operations of a specific element in a diagram based on visibility (i.e.) You can choose to hide all Private or Protected attributes or operations for the said element but have other elements in the diagram display them.
Right click on the notation in questions (say a Class) and select the 'Feature Visibility...' option (CTRL +SHITF+Y).  From the window that appears select the type of attributes or operations you want to hide and those types will not appear for the said element in that diagram.
To set this for all elements in the diagram use the diagram properties option and set the 'Visible Class Members' option.
Also if you want to set all Class diagrams in EA to hide (say) private properties by default you can set up a Class diagram template (Refer 'Templates Package' in help file for detail) and all future class diagrams will hide the private properties in classes by default.
In fact using diagram properties you can set a number of other defaults such as scale to one page, etc.
Hope this helps.
