Author Topic: Representing files in EA  (Read 2685 times)
Robert_K.
« on: May 10, 2006, 05:16:16 am »
In EA 5.0 I have found very nice feature - possibility to model elements named "Artifact" to represent some file on disk (artifact, for example some xls document). By using Ctrl+E shortcut, EA (5.0) opens that file in system default editor. Some times it is important to represent diferent kind of atifacts/files in EA (to integrate them with rest of the analysis model, make relations etc.), and have posibility to fast open them in system default editor/viewer.
BUT THAT DOESN'T WORK IN EA 6.1 :(((( This is a tragedy! :o When I press Ctrl+E - some stupid internal editor opens and show bushes! (And Ctrl+E is for "Open source in external editor" - is this external????!!!) Sparx Systems - what have you done?! Is there any method to show element's associated file in system editor???!
Best Regards, Robert.
Re: Representing files in EA
« Reply #1 on: May 10, 2006, 12:56:09 pm »
Hi Robert,
I think you are in trouble here. The hotkey is now labelled to indicate it is for opening generated source code in the appropriate editor.
For document artifacts - and linked documents in general - EA provides an editor, which is probably the one you are stumbling over. Deep in the help file - under Editing Linked Document Templates you will find, between two graphics, the following phrase: "The Document Template Editor is built into EA."
Sigh...
« Reply #2 on: May 10, 2006, 04:10:17 pm »
Hi Robert,
Open up the options dialog (Tools | Options) and go to the code editors page.  After the list of languages you'll find a checkbox 'Use inbuilt editor if no external editor set'.  If you uncheck that you should get the behaviour you had in version 5.0.
« Last Edit: May 10, 2006, 04:10:30 pm by simonm »
« Reply #3 on: May 10, 2006, 04:44:12 pm »
And then disregard my thoughts on this. Sorry if I ran you around in a circle.
Robert_K.
« Reply #4 on: May 11, 2006, 01:53:07 am »
Thanks simonm, that helped. Now it works exactly as I need.  I was worried about this, because I really need that feature.
Best regards, Robert.
