Author Topic: including files for method parameters  (Read 3322 times)
dwh
« on: June 01, 2006, 05:50:52 pm »
I have defined a class that uses, as a parameter for one of its functions, a reference to another class.
eg
+ handleEvent (event: FlightModeEvent&): void
How can I get the generated code to include the file that defines FlightModeEvent?  If I create an association link, the code generation creates an attribute of that type.  I have tried creating dependency links, <<use>> links, and <<import>> links.
None seem to do the trick.
Any thoughts?
Re: including files for method parameters
« Reply #1 on: June 01, 2006, 11:42:56 pm »
Just a thought, really: Try an explicit dependency since EA does not know about such kind of relations without explicitely being told.
dwh
« Reply #2 on: June 02, 2006, 10:31:52 am »
Do you mean by putting an attribute of the type needed in the class just to generate the include?
Creating a dependency link on its own does not do the trick.
« Last Edit: June 02, 2006, 10:33:36 am by dwh »
« Reply #3 on: June 02, 2006, 02:31:02 pm »
I meant a dependency. For PHP and PERL this generates he include. If for your C#++ it does not do that, I can't help. Someone else?
« Reply #4 on: June 04, 2006, 03:13:27 pm »
Parameter types generally do cause #include statements (or the equivalent in other languages) to be generated by EA.  However, because the parameter is a reference this is causing EA to fail to recognise the classifier.
Also the default C++ templates do not list over all dependencies to create includes.  If you want to modify the code templates I would recommend looking at the default PHP templates as a starting point.
SF_lt
  • The Truth Is Out There
registertm everything to SparX
