Author Topic: connector's color in a profile ?  (Read 9148 times)
moses
« on: September 04, 2005, 12:53:23 am »
did any of you try setting the colour of a connector in an UML profile ?
We tried but no success - I wonder whether this is possible and how :-).
thanks, regards, Moses
Oliver Michalski
Re: connector's color in a profile ?
« Reply #1 on: September 05, 2005, 01:52:17 am »
Hi Moses,
try this way:
1. Open the model where you defined your uml profiles
2. Select your connector and press the key F4
3. Select border color - Deselect Use Default Color
4. Change the color
5. Save Model as UML Profile
Oliver  ;)
moses
« Reply #2 on: September 05, 2005, 05:20:26 am »
it worked, thanks :-)
« Reply #3 on: September 05, 2005, 07:01:35 am »
Hi Moses,
[size=13][SNIP][/size]
Oliver  ;)
Hi Oliver and Moses,
What you've described implies I can change the colour of a connector by applying a profiled stereotype, although I can't change its colour with an unprofiled stereotype.
Is that correct?
If so, can I do it post facto?  That is, having assigned the stereotypes before creating a profile, if I add the profile the colours will magically change?
Questionigly,
« Last Edit: September 05, 2005, 07:05:00 am by PaoloFCantoni »
moses
« Reply #4 on: September 05, 2005, 07:13:45 am »
Hi Paolo,
In general, I think the stereotypes are updated from the profile, so I'd suppose this will happen for the connector, too.
But, bad news :-(. Apparently, the existing connectors won't take the color of the stereotype and the new connector you drag from the profile toolbox won't have the propper color set (default that is) - a problem elements had some time ago, hopefully this will be worked on too :-)
m.
« Reply #5 on: September 05, 2005, 07:25:04 am »
Tried that, but synch does not offer any of the links. Maybe I'm doing something wrong ???
Probably not. I definitely have a link with an according stereotype, but it does not appear in the synch list. I'd call that a bug.
« Last Edit: September 05, 2005, 07:29:53 am by thomaskilian »
Oliver Michalski
« Reply #6 on: September 05, 2005, 08:58:18 am »
Hi Paolo,
no it is not correct. You can change the color foreach stereotypes profiled or  unprofiled. Select the Configuration Menu. Select UML - Stereotypes. Click the Button On the right side from the new window you have the  possibilities for the color selection.
Kind regards from Berlin
Oliver  :)
Oliver Michalski
« Reply #7 on: September 05, 2005, 09:19:00 am »
Hi Paolo,
oops i forgot the second answer.
No they don't change magically the color because the old stereotype and the new stereotype have two different Primary Keys in MS Access
Oliver
« Reply #8 on: September 05, 2005, 11:50:51 am »
Hi Paolo,
no it is not correct. You can change the color for each stereotypes profiled or  unprofiled. Select the Configuration Menu. Select UML - Stereotypes. Click the Button On the right side from the new window you have the  possibilities for the color selection.
Oliver  :)
Oliver, this never used to work for connectors (it does for shapes). and for me still doesn't. :(  Which version are you using?
Thomas, can you do it?
« Reply #9 on: September 05, 2005, 12:41:56 pm »
Doesn't work, although it looks as it should ???. Never made use of that before, so I can't tell really :-[
Oliver Michalski
« Reply #10 on: September 06, 2005, 01:26:12 am »
Hi Paolo,
Hi Thomas,
I had not tested this with connectoren  :-[. It doesn't work for me too.  :'(
A view into the data base shows however, that EA has the changed configuration stored.
I think it is a bug.
Oliver  ???
« Reply #11 on: September 06, 2005, 02:45:57 am »
Has anyone the need for sending a bug report?
Oliver Michalski
« Reply #12 on: September 06, 2005, 03:09:10 am »
I have send a bug report
Oliver  :)
« Reply #13 on: September 06, 2005, 04:25:26 am »
Thanks, neighbour :)
Oliver Michalski
« Reply #14 on: September 13, 2005, 10:01:33 am »
I have an answer from sparx support:
>>This is an issue that we are aware of and hopefully it will be fixed in a near future release of EA.<<
Oliver  :D
