Author Topic: Release Plan  (Read 4801 times)
schoetbi
Release Plan
« on: November 13, 2006, 02:24:11 am »
I am looking for a possiblity to manage release plans in EA. Is there a possibility to do this?
Thank you.
Tobias
Jan ´Bary´ Glas
  • Bary
Re: Release Plan
« Reply #1 on: November 13, 2006, 03:44:37 am »
You may prioritize your elements or make packages Release 1, Release 2,...
Jan 'Bary' Glas
peter.zrnko
Re: Release Plan
« Reply #2 on: November 13, 2006, 03:59:17 am »
What about to make a special element "Release No x" and link (or crossreference) it with features that are planned for this release?
I'm not using this schema. It's only a thought.
Peter
schoetbi
Re: Release Plan
« Reply #3 on: November 13, 2006, 05:22:32 am »
Thanks for the answers. Creating a package will probably help in wrapping the requirements together. Another feature I don't know if it is available is that after creating the packages I would like to see what work needs to be done to implement this particular release. Do you have any ideas how I can link the requirements to the use-cases and classes with the attached time for implementation?
Thank you,
Tobias
Jan ´Bary´ Glas
  • Bary
Re: Release Plan
« Reply #4 on: November 13, 2006, 05:28:42 am »
You may attach Reqs to elements simply by drag in Project Browser and drop onto an element in a diagram.
Jan 'Bary' Glas
Re: Release Plan
« Reply #5 on: November 13, 2006, 06:51:26 am »
You could use Phase and Version defined in all element's properties. Alternatively/also you could make use of Tags.
schoetbi
Re: Release Plan
« Reply #6 on: November 19, 2006, 11:26:53 pm »
Thank you very mouch for your replys.
I have releases with the selected requirements in it.
For each requirement I have usecases or classes realizing it.
For each realization I can have an estimation or an effort attached to it.
Have I understodt this structure correct?
If yes is there a way to model the whole flow inside EA and to get the number of hours needed for a particular relase?
Thank you for any help.
regards,
Tobias
Re: Release Plan
« Reply #7 on: November 20, 2006, 12:26:40 am »
Hi Tobias,
check Project/Use Case Metrics. This lets you do calculations in the way you need it. I had a quite long discussion with Bruno Cossi some 2 years ago about metrics. Don't know whether you can reveal this using the seach (I have the impression, this does not work so well).
schoetbi
Re: Release Plan
« Reply #8 on: November 20, 2006, 01:17:59 am »
Because of the lack of good searching in EA. I do many searchoperations direct with MS-Query:-)
I will check if the metrics will work for me. When I first looked at it I had the impression that they are quite complex to use.
Tobias
peter.zrnko
Re: Release Plan
« Reply #9 on: November 20, 2006, 01:25:32 am »
Regarding searching - have you tried Edit - Find in Project - Advanced - New Search - Query builder or SQL editor ?
Peter
schoetbi
Re: Release Plan
« Reply #10 on: November 24, 2006, 02:32:34 am »
Hello Peter,
Thank you very mouch for this. I even programmed queries in other programs to get the apropriate reports from the data.
It's a very nice feature.
regards,
Tobias
