Author Topic: How set db table data type ? (EA Corp Ed 6.5.800)  (Read 2339 times)
stigva
« on: December 15, 2006, 12:04:36 am »
I can set default database under
<menu>->Settings->Database Datatypes->(set as default)
But every time I return the dropdown does not show last selected default database and the checkbox is unmarked.
When I drop a table in a fresh diagram, I need to set the data types for columns. But when I on a table go:
properties->table details->column/attributes->(Data type) the is just no data types (varchar, number,..) dropdown to select from?!
/Stig
Re: How set db table data type ? (EA Corp Ed 6.5.8
« Reply #1 on: December 15, 2006, 12:51:59 am »
Hi Stig,
Check the Default Database as defined in: Tools|Options|Source Code Engineering|Code Editors|DDL.  Is this the same value you set by the other means?  If NOT, set it here...
If it already is the same, then I can't help you...
Welcome to EA's UI (Unique Interface)...
