Author Topic: Import oracle number column default precision  (Read 2833 times)
Christopher Pierce
« on: October 05, 2006, 12:41:53 pm »
I am trying to import an Oracle 9i schema where one of the tables has a column of type NUMBER with no precision specified.
create table TEST (
  MY_NUM_COL NUMBER
The problem is that when I import this table, the number column in question is always imported with the precision defaulted to 15.
Is there a way to change this default behavior? (i.e., have it default to 38)
I noticed that in "Settings"->"Database Datatypes", you can select "Oracle" as a product, and it has the "default" for NUMBER set to (8,2), but this seems to only work as the default when creating a new table via EA.
Christopher Pierce
Christopher Pierce
Re: Import oracle number column default precision
« Reply #1 on: January 10, 2007, 07:49:49 am »
I noticed that build 800 had the following change log entry:
"Improved import of Oracle NUMBER datatype to distinguish between NUMBER, NUMBER(50), NUMBER(10,2) types."
So I tried downloading the latest build (802) to see if it helped my problem, but it doesn't (NUMBER type still imported with default precision of 15, and I still can't find a way to change this behavior).
Is a there a way to find out the details of the bug that this change log entry fixed?
