Author Topic: BUG: Weighted "flow" edges corrupt name  (Read 2139 times)
« on: January 11, 2007, 07:26:13 pm »
[glb]This one is a real duzy![/glb]
The "flow" edges display the weight by means of a Top_Mid_Label.
When you open a previously created edge with a blank name property, it places the Top_Mid_Label DB column value into the name property!
Even if you remove the weight it won't go away!
There appears NO WAY (short of direct DB surgery to kill the Top_Mid_Label and Name column values - that is, putting a stake through its heart after shooting it with a silver bullet ::)) to remove the ... (sucker).
This needs an immediate fix!
[size=10]Enterprise Architect appears to have an (Ab)User Interface![/size] TM[/color]
