Author Topic: error importing source  (Read 3014 times)
mansour77
« on: January 17, 2007, 12:06:01 pm »
I am getting this error trying to import a VB.NET class:
There was an error parsing C:\VisualStudioProjects\MyProject\MyClass.vb on line 49.  Unexpected symbol: [
and in the class file, line 49 contains somehting similar to:
Private Sub LoadClass(ByVal ExternalFile As [Assembly], ByVal ClassType As Type)
PLease note the code compiles and run fine in VS.
Re: error importing source
« Reply #1 on: January 17, 2007, 12:10:17 pm »
Is there some way you can rename the [Assembly] type - which I'm assuming is something you've defined elsewhere?
If so, see if the square brackets are causing the problem.
Regardless, you should report this to Sparx as a bug. Use the Support link at the top of your forum page, or from the EA main menu choose Help | On-line Resources | Bug Report Page.
« Reply #2 on: January 17, 2007, 02:37:56 pm »
I can confirm that this is an issue with the escaped keyword as a type.  We'll fix this as soon as possible.
« Reply #3 on: January 17, 2007, 02:45:40 pm »
Thanks Simon,
I was guessing there, but it's good to know you guys have it in your sights.
