Author Topic: Stereotypes and predefined Attributes and OCL  (Read 3580 times)
SaschaR
« on: March 07, 2007, 02:56:12 am »
I just created a profile, that contains a stereotype and extends the metaclass "activity". I created a shape script, that change the appearance.
Now I want to add attributes to the stereotype (like an string id) , that should be predefined in every stereotype, that I use from the toolbar in any diagram. But when I define an attribute at the stereotype in the profile view, it isnt transformed to the diagram, where I use the stereotype. I know I can make tagged values, but thats not really what I want, because I want to be sure, that everyone who use this stereotype also use the attribute. What can I do about it?
Another issue is : Does OCL works with EA? I tried to force, that a stereotype has alwasy a link to e.g. a use-case diagram and tried this with the ocl expression inv: self.UMLDiagram->size()>1 but it didnt work?
« Last Edit: March 07, 2007, 04:24:54 am by SaschaR »
Re: Stereotypes and predefined Attributes and OCL
« Reply #1 on: March 07, 2007, 12:45:12 pm »
Only an answer to your 2nd question: No, not really. You can write OCL and EA does some kind of syntax checking on OCL. But (obviously) no semantics. Although they claimed it to work.
SaschaR
« Reply #2 on: March 07, 2007, 11:08:36 pm »
Thank you for your answer. Maybe another question : Is it planned to implement a wider support for OCL in  the near future? And is a feature request a way to speed things up?
« Reply #3 on: March 08, 2007, 08:03:45 am »
You have to ask Sparx directly. You can post a feature request on the appropriate board and additionally via registered user request page. There are quite some people using OCL but I don't know to which extend. Maybe you browse a bit through the existing threads.
