Author Topic: How to enumerate Actors of a Use Case in a Report?  (Read 3554 times)
MarkusKlein
« on: March 14, 2007, 09:52:35 am »
Hi there!
Can you give me a clue how to enumerate all Actors (but only the Actors!) of every Use Case in an (RTF-)Report?
I want to generate a "Alistar Cockburn"-like Use Case documents automatically. I don't want to edit the actor as text but use the existing "Association" in the Use Case Diagram.
So every Use Case should have a list of it's Actors (maybe a "Primary Actor"), additional information and the Scenario(s) of the Use Case ...
Thanks in advance, greetings
 markus
bioform
  • Forty-Two?
Re: How to enumerate Actors of a Use Case in a Rep
« Reply #1 on: March 18, 2007, 08:16:39 pm »
I have had VERY little luck using the RTF reports, and currently use MS Access/MS WORD to generate all documentation for my EA models... This is a VERY effective method that allows you to easily customize the documentation to your specific needs....
The only caveat I have is that you need to access the RDBMS tables of the project.... I currently run EA on my laptop, with my projects hosted on SQL Server 2005 Desktop edition...
If you want some specifics on the approach, let me know.
Time is what keeps everything from happening at once, Space is what keeps it all from happening to you. <unknown>
« Reply #2 on: March 18, 2007, 10:51:42 pm »
David,
I think a number of us would be interested in how your approach works.  Would it be possible to add it to the EA Wiki?  Preferably with a worked example? ;D
Thanx,
« Last Edit: March 18, 2007, 10:51:59 pm by PaoloFCantoni »
MarkusKlein
« Reply #3 on: March 19, 2007, 02:04:42 am »
Hello David!
I would be very, very, very interested :-))
It seems that there is no other way...
 markus
SaschaR
« Reply #4 on: March 20, 2007, 10:51:34 pm »
Hello David,
I would be very interested too.
