Author Topic: Custom Stereotypes and metafiles  (Read 2330 times)
bdetchevery
« on: March 23, 2007, 11:29:45 am »
I am a newbie to EA, but so far I am really enjoying it. I searched for my problem on this board, but was unable to find it.
I am using EA 6.5.804 and I am having trouble using custom images for my stereotypes.
What I would like to do is have several custom images for my databases. I would like it so that each time I reference my database in any diagram that it uses the same image (and not the default entity image)
I have created a custom stereotype (eg: AccessDB), and have set a custom EMF file, (it shows up correctly in the preview window under Settings->UML->Stereotypes), but when I try to use it (ie: put it on a diagram) it shows just a box (I think the standard object box) and not the Metafile.
Any ideas what I'm doing wrong?
Tks,
Brad D. :-)
http://www.articleswap.biz
Re: Custom Stereotypes and metafiles
« Reply #1 on: March 23, 2007, 12:15:55 pm »
Try dbl-clicking the diagram and look whether the Show stereotype icons is checked.
bdetchevery
« Reply #2 on: March 26, 2007, 03:29:05 am »
Yep, the 'show sterotypes icon' was clicked on the Diagram packages.
I finally did get it to work, under Settings -> UML -> Sterotypes. I created a new sterotype with base class 'business class'. I chose this as I was trying to model the 'entity' sterotype' which also used 'business class'. This prevents the custom metafile from displaying.
Once i changed the Base Class to 'object', then the metafile showed correctly.
Tks,
Brad D. :-)
