Author Topic: EA Object model available?  (Read 3317 times)
Jos Fries
« on: March 08, 2008, 11:36:07 pm »
Is the EA object model as documented in the EA help http://www.sparxsystems.com.au/EAUserGuide/automationinterface.htm available as a EAP (or XMI) file? This would be a great help in writing add-ins, e.g. to generate wrapper code. Currently I'm reverse engineering this model from Interop.EA.dll but it would be much easier if that model were generally available.
Jos
Re: EA Object model available?
« Reply #1 on: March 09, 2008, 12:49:25 am »
Sorry Jos,
If such a model is available we've not seen it, despite numerous requests. The best we've been able to do is the same reverse engineering trick you have.
I am assuming that you reverse engineered via the Import Binary Module function. If not, that's the best way to go. [Which still does not qualify as good news.]
I wish I had a more positive answer.   :(
