Author Topic: Basic Template RTF Export  (Read 2702 times)
Marcel
« on: April 24, 2007, 02:29:06 am »
I just tried to create a RTF Export with the Basic Template. That looks nice, but has some elements in it, I don't need.
But, I can't edit it, the Button "edit current" is disable.
Is there a possibility to edit the template? Would be stupid if I had to rebuild the whole template except the few features I don't need.
Thanks for your answers!
stella4000
Re: Basic Template RTF Export
« Reply #1 on: April 24, 2007, 11:23:59 am »
You can create a new template based on the template you liked.  When you open the documentation dialog box, click on Manage Templates, a dialog box will open up; click on New and give your new template a name. From the 'Copy Template' drop down menu select the template you want to use and click ok. Your new template should now show up in the list of templates which you can now edit as you want.
Hope this helps.
Marcel
« Reply #2 on: April 24, 2007, 09:32:41 pm »
Ah, thank you! I will try it :)
