Author Topic: Including Other Users Packages  (Read 1961 times)
raj
« on: May 31, 2007, 11:18:20 am »
Hello All, I am a newbie here. Excuse me if you have answered this question already in this forum.
We use Clearcase as our source control application. We create packages and add them to source control using a common source control configuration.
I have problem bringing in others packages into my project. When I try to get others packages following the instructions from chapter/section "Including Other Users Packages" in EA help, I do not see any packages in the list. I have copied the help contents below. The dialog mentioned in step 3 of instructions always comes up empty.
This used to work fine in EA 6.1. But stopped working when we moved to EA 6.5.
Any help is appreciated. Thanks.
Here is the chapter from EA help I was talking about -
Packages that have been created by other users, or by yourself in another model, can be retrieved from version control and imported into your current model, by using the Get Package command.
Other users may be creating packages that you wish to use in your model.  If you are not sharing a SQL database or EAP file, those packages will not automatically become part of your model.  If the packages have been placed into version control, they may be retrieved and imported into your model as children of an existing package, using the Get Package command.
You must have access to the package files through the version control system and you must define a version control configuration through which to access those files.  The version control configuration must use the same Unique Id that was originally used to add the package to version control.
1. In the Project Browser, right-click on a package that you wish to use as the parent of the incoming package.
2. From the Package Control submenu, select Get Package.
3.  The following dialog will open.
   <Dialog that is supposed to list packages>
4.  From the drop-down list, select the version control configuration associated with the package you wish to retrieve.  The file list will then be populated with the names of files available through that configuration, for retrieval and import into your model.
5.  Select the package file you wish to import into your model and click OK.
Re: Including Other Users Packages
« Reply #1 on: May 31, 2007, 01:17:51 pm »
I really don't know Raj. But here's a few ideas that might work, and they won't set you back.
Before you go too far on this, check that you are using the most recent build of 6.5 - they released build 806 last month (April 2007) sometime.
Check the release notes for the 6.5 builds to see if anything got changed.
Finally, pull down the most recent help file from the Sparx site. Your build might have been upgraded (from the original 6.5 build) using the patch file method, which does not update the help file.
