Author Topic: Responsibilities Tab  (Read 7897 times)
jeshaw2
« on: June 16, 2007, 09:10:04 pm »
Context EA Beta 7/2
How do I get the "Responsibilities" tab on a class's property screen to appear?  I've activated the feature's visibility check-box.
Re: Responsibilities Tab
« Reply #1 on: June 16, 2007, 10:53:21 pm »
Where did you enable it? I have no problem with 7.1 when dbl-clicking the diagram.
jeshaw2
« Reply #2 on: June 17, 2007, 12:40:20 pm »
Just figured it out.
Apparently EA has decided to call the Responsibilities tab the Requirements tab.  A bit confusing I think specially when the EA help file calls the Requirements tab the Responsibilities tab.
« Reply #3 on: June 17, 2007, 02:42:12 pm »
IMHO, that deserves a bug report. Don't matter which one's wrong, a repair is required.
jeshaw2
« Reply #4 on: June 17, 2007, 03:53:19 pm »
Bug report has been submitted.
« Reply #5 on: June 17, 2007, 05:42:34 pm »
Jim,  AFAIK, it has always been thus...  This probably what got me started on the CCC line years ago.  The tab says: Require, the checkbox: [X] Requirements but the display and the help (correctly, in my view) say responsibilities
« Reply #6 on: June 17, 2007, 06:00:21 pm »
Perhaps this will be a move towards CCC.
We live in hope...
jeshaw2
« Reply #7 on: June 17, 2007, 06:09:59 pm »
I agree that Responsibilities is the correct term and said so in my bug post.
OOPS! I just received a reply from Sparks:
We have tried changing this name to responsibilities in the past, but received a lot of negative feed back so it has been left as is. However, we will make the necessary help updates to properly reflect the current tab name for that dialog to remove confusion.
 Looks like they will solve the CCC problem.   ::)
« Reply #8 on: June 18, 2007, 01:19:19 am »
So we seem to be adrift, but in the correct direction.
Not bad, all things considered.
« Reply #9 on: June 18, 2007, 02:57:41 am »
Yes, it's better to be consistently wrong than inconsistently wrong...   ;)
I'm opening a book that they DON'T catch all the places in one go...
