Author Topic: EA 7.0 confusing installation instructions  (Read 5575 times)
fbachaalani
« on: August 07, 2007, 05:05:22 am »
Hi guys,
This is my first time on this forum.
I have EA 6.5 installed and being a registered user, just downloaded 7.0Only I downloaded both the easetupful.exe as well as the patch, EA70.zip.
Reading the installation instructions I had no way to know whether they are both mandatory to be installed or not, my questions:
1- Do I have to uninstall 6.5 or I can I simply install over it?
2- Could I just apply the patch directly on top of the 6.5 installation or should I, as suggested, first use easetupfull.exe?
3- If answer to 2: must use easetupfull, then should I still apply the patch? i.e. the patch is mandatory to apply for a valid EA 7.0 full install?
Thanks for your help (I have not trie anything yet, just wanted to learn the process for futurepotential upgrades)
FAD
Martin Terreni
  • Sorry, I can't write
Re: EA 7.0 confusing installation instructions
« Reply #1 on: August 07, 2007, 05:16:35 am »
keep it simple.
just D/L easetupfull and run it.
Recursion definition:
« Reply #2 on: August 07, 2007, 01:01:20 pm »
The patch file is an alternate way of upgrading from the previous build of EA and should not be used across different versions.
fbachaalani
« Reply #3 on: August 08, 2007, 10:26:49 am »
Thanks guys.  :)
Simonm: Would be good to add this extra information to the installation steps as it is not mentioned anywhere. (anywhere obvious that is)
Cheers  :D
Dave_Bullet
« Reply #4 on: August 08, 2007, 02:08:12 pm »
um... Sparx have made it obvious.  I think the download page (if you read it) warns you that you need the full easetup if going to a new major version..
We'll I knew that before I "upgraded" as I un-installed / re-installed the new version.
David.
pborcic
« Reply #5 on: August 16, 2007, 11:39:42 am »
We're using EA 6.5 with the project stored in SQL Server.
If I upgrade to EA 7.0 will I screw up anything for those users still using EA 6.5? Or do I have to get everyone on the project to upgrade at the same time?
« Reply #6 on: August 16, 2007, 12:21:53 pm »
Please see this thread: http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1187113393
pborcic
« Reply #7 on: August 16, 2007, 12:26:17 pm »
Missed that one when I was searching the forums.
Thanks!
