Author Topic: UI element name not over element  (Read 2389 times)
Martin Terreni
  • Sorry, I can't write
« on: August 22, 2007, 08:53:49 pm »
For all relevant UI  elements in EA the name of the element is placed directly over the element. However when I creta a new element or change the apirience the name is place under the element.
This is some where between problematic to not corect, since if I create, for example, a new king of botton I would expect its name to apear over it same as normal UI <<Button>> object.
Is ther some trick to fix it?
Recursion definition:
