Author Topic: Attribute Constraints  (Read 3987 times)
StanKostoff
« on: October 11, 2007, 11:23:43 am »
How do you view attribute constraints for classes?  I've checked the element and diagram options to view constaints with no success.  If I add a constraint to the class properties, the constraint displays.
Re: Attribute Constraints
« Reply #1 on: October 11, 2007, 11:50:26 am »
Create the attribute in question, and make sure you save it.
Then open attribute properties (or select the class and press F9). You should see a Constraints tab, which will allow you to work your magic.
HTH, David
StanKostoff
« Reply #2 on: October 11, 2007, 11:58:02 am »
Did that.  How do I view the attribute contraint in the Class diagram--not the constraint in the attribute properties window?
peter.zrnko
« Reply #3 on: October 11, 2007, 11:11:24 pm »
As far as I know, it's not possible to view Attribute Constraint in the diagram.
Peter
« Reply #4 on: October 12, 2007, 04:37:57 am »
I just checked, and it appears you cannot even get at the attribute constraint via a linked note.
This would make a good feature request. Why not send it in Stan?
Please search my recent posts for a best practice we use for feature requests and bug reports.
