Author Topic: BUG: Spell check doesn't refresh anything  (Read 2641 times)
« on: October 21, 2007, 04:37:03 pm »
I just spell checked a package and when I finished I checked the diagram - NOT refreshed.  Well browser-diagram synchronization is an on-going issue for EA.
Check browser it is also NOT refreshed!
I presume , if I make changes to the item in the browser, it will overwrite the spell check fixes in the database!  ::)
Certainly, manually refreshing the diagram (and, I suspect, the package in the browser) makes the prior spell check changes current.
If EA is only spell checking the repository then it MUST refresh the memory!
This needs to be fixed ASAP!
[size=10]Using EA in spite of EA, NOT because of it![/size] TM[/color]
