Author Topic: Table operation drag+drop problems  (Read 2115 times)
« on: October 22, 2007, 07:05:18 pm »
As with other types of classifiers, EA allows you to drag and drop operations and attributes between data modelling elements.
However, when you drag an operation that contains a column (parameter) that doesn't exist in the new classifier AND you have a need to delete the column, you can't!  The delete button has no apparent effect.
In addition, if you try to modify it to use an existing column - when you save the "overridden" column, EA creates a new parameter and leaves the invalid one in place.
These anomalies need to be rectified.
