Author Topic: Show multiplicity of components on diagram?  (Read 10755 times)
bknoth2
« on: October 30, 2007, 03:56:23 pm »
Is there a simple way to show multiplicity of components on component diagrams? I'd like to make it clear when a component symbol represents multiple instances of the component.
Maybe I'm overlooking something, but I haven't found a way to do it.
Bruce
Re: Show multiplicity of components on diagram?
« Reply #1 on: October 30, 2007, 03:58:22 pm »
You could always use a note.
bknoth2
« Reply #2 on: October 30, 2007, 07:35:39 pm »
I could, but that isn't a very pleasing solution, and I already have a reasonably complex diagram. With object-icons in EA, you can show the multiplicity and have it show up in the upper right corner of the icon. It would be nice to have something concise like that.
« Reply #3 on: October 31, 2007, 03:39:34 am »
I agree Bruce,
Perhaps you could drop a text element onto the diagram. This has severe limitations - it is semantically weak as well as being a disaster if you make a major change to the layout - but for presentation purposes it would likely do the trick.
Gary W.
« Reply #4 on: October 31, 2007, 12:09:24 pm »
Martin Fowler has an example where a Device Node has an attribute named 'number deployed', and it's set to '3' (i.e. number deployed = 3).
It's in his UML Distilled (3rd ed.) book, in Chapter 8 (page 98 ).  I know it's a node, but you could do something similar for a component, and it would definitely show the mutiplicity.
gary
« Last Edit: October 31, 2007, 12:10:53 pm by gwong »
bknoth2
« Reply #5 on: October 31, 2007, 12:32:02 pm »
Thanks - I'll look into that.
- Bruce
« Reply #6 on: November 02, 2007, 03:07:40 am »
AFAIK you can simply use the Multiplicity from the element properties. They appear in curly brackets.
bknoth2
« Reply #7 on: November 02, 2007, 07:19:54 am »
I've tried that but I don't see the value show up. Is there a place to turn on the visibility for the multiplicity?
Bruce
« Reply #8 on: November 03, 2007, 03:10:20 am »
I see. Once it was missing for Node elements and after a bug fix it appeared. So I would send a bug report. Also report that the Runstate can be set, but does also not appear.
