Author Topic: Problem with code synchronization and #else block  (Read 2821 times)
AndiA
« on: November 29, 2007, 05:00:01 am »
we are using C code in Enterprise Architect (7.0.818 Professional) with code reverse engineering.
I have a problem when there is an #else statement in the code
EA ignores every element in this #else block
e.g.:
#if !defined _MODULE_
int var1 = 123;
#else
int var2 = 123;
#endif
On code reverse engineering var2 is ignored here.
My current workaround is to replace the #else by another #if statement:
int var1 = 123;
#endif
#if defined _MODULE_
int var2 = 123;
#endif
Is it possible to ignore the #else statement via the Preprocessor Macros somehow
or is there any other solution?
Andi
Re: Problem with code synchronization and #else bl
« Reply #1 on: November 29, 2007, 11:23:43 am »
I'm afraid that EA explicitly ignores everything inside else blocks because if it doesn't there are situations where the file becomes impossible to parse.
