Author Topic: Import DB clears Database field  (Read 5284 times)
Bill Egge
« on: April 19, 2005, 07:55:20 am »
I am importing a Pervasive database.  First, I added Pervasive to the Database Datatypes dialog by clicking the Add Product button then adding data types.
If I try and import a table from a pervasive database all the column datatypes show up as varchar and the database attribute for the table is not set, it is empty.
So, I set all the imported tables database attribute to Pervasive and then did a re-import and chose Synchronize existing classes.  This has the effect of clearing the database attribute of the table and resetting any columns back to varchar.
Am I missing something or is there no way for EA to import Pervasive tables?
Also, would Sparx consider outsourcing implementation of this feature to me?
plopes
Re: Import DB clears Database field
« Reply #1 on: November 24, 2005, 02:07:46 am »
Hi!
I have the same problem!
Is there any solution?
Pedro Lopes
hd
« Reply #2 on: November 24, 2005, 01:32:56 pm »
EA does not have support for importing schema from Pervasive,:(
which is why the datatypes are set to the default varchar.
rneelakantan
« Reply #3 on: February 24, 2006, 11:35:54 am »
I tried to import oracle (8i and 9i) schema and all the attributes are set to varchar.  Used Oracle ODBC Driver.
Mr._D
« Reply #4 on: January 07, 2008, 06:41:30 am »
And if they do, could you please let me know?  I'm entering the schema for a large database at the moment, and it's a chore.
