Author Topic: Auto lay out restes row type  (Read 4228 times)
Martin Terreni
  • Sorry, I can't write
« on: January 19, 2008, 03:15:18 am »
Auto lay out restes row type to direct (also in 7.1).
bug reported
Recursion definition:
Re: Auto lay out restes row type
« Reply #1 on: January 19, 2008, 07:17:08 am »
Do you mean Routing type?
This has always been a problem. Layout sometimes also inserts bend points in the lines at strange places and angles.
Martin Terreni
« Reply #2 on: January 19, 2008, 08:13:40 pm »
Do we have here traces of AI?  ;D
« Reply #3 on: January 20, 2008, 03:33:50 am »
Or perhaps this is the AI of traces.  ;D
Martin Terreni
« Reply #4 on: January 27, 2008, 01:08:02 am »
Hello Martin,
Thanks for your email regarding autolayout. The connectors styles are actually set to the "Custom Line" style by the Auto Layout routine. This is intended behaviour, as the layout algorithm calculates where to put line waypoints based on the hierachy. The custom line style is the only line style that allows for this level of control over how lines are drawn, and thus all lines are set to use that style.
OK, then I guess it will stay this way...
« Reply #5 on: January 28, 2008, 05:58:01 am »
Martin,
the autolayout is definitely not the cream. In best case it's butter milk. I meanwhile found out where to use it and where not. E.g. for Ports it doesn't do anything (except scrapping the layout :(). However, I made workarounds with add-ins which definitely improves work. It would be nice it the autolayout itself was available as modifiable script so one could make changes on his own. Wishful thinking...
