Author Topic: No XSD type found for: "XType" Defau is: xs:string  (Read 4550 times)
pstein
« on: March 21, 2008, 08:23:03 pm »
I generate an XSD schema file from a given XSD model. However during the generation EA tells me
some warnings similar to:
Warning: No XSD type found for: "XXXType" Default is: xs:string
Much to my surprise EA does NOT recognize some existing type defintions. XXXType exists!!
When I open the classes attribute list and re-select the type (by opening the drop down menu without changing the type) and finally click on the button "Save" then the warning goes away in the next XSD file generation operation.
The resulting XSD file now contains the correct file type and is not any more replaced by string.
Why does EA not recognize the Type in the first step?
Peter
dorian
Re: No XSD type found for: "XType" Defau is: xs:string
« Reply #1 on: December 13, 2018, 01:05:07 am »
the same happens to me when generating a scheme, because references are lost,
If I put them to work but then they get lost again,
 any way to solve this?
        Warning no XSD type found for: "Entrada".  Default is: xs:string
   Warning no XSD type found for: "Alert".  Default is: xs:string
   Warning no XSD type found for: "Cliente".  Default is: xs:string
   Warning no XSD type found for: "Solicitud".  Default is: xs:string
   Warning no XSD type found for: "Salida".  Default is: xs:string
« Reply #2 on: December 13, 2018, 01:13:05 am »
Dorian,
I think you better create a new topic; you replied on a post from 2008.
I doubt a 10 year old issue is still relevant today
Anyway, you should include much more info to get meaningful help.
All the mind-readers on this forum are on holiday for the moment. ;)
Glassboy
« Reply #3 on: December 13, 2018, 08:26:29 am »
Dorian,
10 years is nothing to a man with a portrait in his basement :-)
« Reply #4 on: December 13, 2018, 09:29:29 am »
Dorian,
Especially on planet Sparx.
EA even provides a special theme for Dorian.  ;)
