Author Topic: Setting up CVS with ext protocol  (Read 3648 times)
esuarez
« on: April 25, 2007, 10:29:23 am »
Hi there,
Is anybody using EA with CVS with a protocol other than pserver?
I started a proof-of-concept project for using EA in our team using version control, and setup a local repository with CVSNT and used the pserver protocol with no problems.
Now that I want to deploy the project to an enterprise-wide CVS repository that only handles ext, ssh and extssh, EA is giving me all kinds of errors that cannot connect.
I have tried installing the OpenSSH that comes with Cygwin because the initial error I was having was that EA through CVS could not connect to the server via SSH.
Has anybody successfully created an EA project with CVS?
-Emilio Suarez
bob_d
Re: Setting up CVS with ext protocol
« Reply #1 on: April 03, 2008, 06:34:10 am »
Late reply, but I am doing this using ext and Tortoise CVS.  We use putty for SSH.  Biggest trick is that you need to set the environmental variable CVS_RSH to point to the plink.exe or you will get the error you describe.
"Whoever undertakes to set himself up as a judge of Truth and
Knowledge is shipwrecked by the laughter of the gods." - Albert Einstein
