Author Topic: UML Patterns  (Read 3745 times)
WvanBeek
UML Patterns
« on: June 04, 2008, 11:41:11 pm »
L.S.,
I want to build a UML pattern conatining several classes. Of course, I can use a classdiagram, choose Diagram > Save as UML Pattern... The classes on the diagram however, have generalization relations to other classes, located in packages in other models wihtin the same eap file. These classes are not viewed on the classdiagram. So when I build a UML-pattern, the inheritance relationships are lost, which is strange, because they do exist in XML file pertaining to the stored pattern.
How can I retain the inheritance ?
Any help is appreciated,
regards,
Will
WvanBeek
Re: UML Patterns
« Reply #1 on: June 05, 2008, 04:05:56 pm »
L.S.,
I have gone a bit further and added shortcuts (simple links) of the super classes to the classdiagram. When exporting this pattern, the super classes are set to merge; all the other classes are set to be created. After reimporting this as a pattern, I have to merge or link the super classes back to their actual location in the eap file. And after dropping the classes on a new classdiagram, I remove the shortcuts to the super classes and I have got what I want.
I can understand that a UML pattern ignores packages and therefore the actual location of classes in the eap file, but in my case classes always inherit functionality from the same particular super classes, that are always in the same location in the eap file.
So, is there a way to do the import with an automated merge, since the location of the super classes in the eap is already known in the xml pattern file, designated by the namespace.
TIA and regards,
Will
