Author Topic: How to get image to appear in posting  (Read 4176 times)
jamessher
« on: May 15, 2008, 03:50:06 pm »
I've tried the image tags but can't see how to upload and image so that it can appear in a posting to this forum. I put my image on an image sharing site and put the URL in the image tags but that didn't work.
Can someone please explain how to do it ?
    James
Dermot
Re: How to get image to appear in posting
« Reply #1 on: May 15, 2008, 04:52:52 pm »
Not sure if it is case sensitive on the marker or you need the URL marker, but here is an example of one that works (square brakets replaced with {}:
{URL=http://img104.imageshack.us/my.php?image=projectbrowsersz2.png}{IMG}http://img104.imageshack.us/img104/6391/projectbrowsersz2.th.png{/IMG}{/URL}
(from another forum entry)
« Last Edit: May 15, 2008, 04:59:27 pm by Dermot »
« Reply #2 on: May 15, 2008, 04:53:35 pm »
Hi James,
This forum can't host your images, so you have the right idea hosting them at some other site. I notice you are using imageshack. I use that site too. It will give you the choice of 5 links: use "Direct"  (the last one)
jamessher
« Reply #3 on: May 15, 2008, 04:54:39 pm »
Hi Dermot - would you mind explaining how you did it ?
Dermot
« Reply #4 on: May 15, 2008, 04:57:13 pm »
I have re-set the bracketing to show the text.  See above - refresh.
Note: the last char in the {/URL - has been set - to Ascii code - it should be '}'.
« Last Edit: May 15, 2008, 05:01:50 pm by Dermot »
jamessher
« Reply #5 on: May 15, 2008, 06:49:42 pm »
Thanks Dermot
I'll have another go here.... looks like it works now - problem I think was I wasn't using the correct form of URL
jamessher
« Reply #6 on: May 15, 2008, 06:50:19 pm »
Sorry Dermot - forgot to thank you for your help
Cheers
    James
