Author Topic: Relationship Matrix  (Read 3341 times)
tpsdev
Relationship Matrix
« on: May 21, 2008, 06:39:51 am »
Anyone know how to keep the green squares and x's visible on a saved profile after closing it?
The relationship matrix view does not keep the x's after we close it.  I suspect it has something to do with our settings between entities.
Transition Technologies
Re: Relationship Matrix
« Reply #1 on: May 21, 2008, 05:20:05 pm »
It does keep the relationships, however after opening it again you have to specify again needed source, target and types. Post if that does not help.
Authorized Reseller and Training Partner of Sparx Systems
www.ea.tt.com.pl
thomas.kilian
« Reply #2 on: May 21, 2008, 05:26:10 pm »
You can save a search as profile so you don't have to manually redo the settings.
« Reply #3 on: May 21, 2008, 07:13:48 pm »
Good point abcde. We can save few profiles and run them easily.
www.ea.tt.com.pl
tpsdev
« Reply #4 on: May 22, 2008, 02:07:44 am »
It was a setting.  It appears that EA allows you to create a matrix, without specifying a source or target.  These are necessary if you want to see the green boxes with x's.
I've saved my settings as a profile and when I open the matrix up again it works as advertised and I see those reassuring green boxes and x's.
Seems like a logical bug.  As a programmer, I would have forced the user to start with the source and targets so that they would get the behaviour expected from the matrix interface.
Thanks for all the helpful posts.  You've enabled my project to use EA in yet another super time saving way.
 ;D
« Last Edit: May 22, 2008, 02:09:40 am by tpsdev »
