Author Topic: Problem with headings  (Read 3558 times)
bla
« on: September 26, 2008, 08:29:32 pm »
by generating the rtf report i get table of contens but without the root package, which is included in the contents of tables but without the number one.
Examples      5
1.1    Business Context      5
1.1.1    Strategies      6
1.1.2    Stakeholders      6
1.1.3    Topology      7
1.2    Business Objects      7
1.3    Business Workflows      7
i need :
1. Examples 5
1.1 .....
« Last Edit: September 26, 2008, 08:46:22 pm by bla »
marcel_str
Re: Problem with headings
« Reply #1 on: September 26, 2008, 11:34:20 pm »
Check out the style used for Table of contents in the document. If numbering is not specified (I guess for style TOC1 in your case), this could be the output.
bla
« Reply #2 on: October 01, 2008, 09:38:19 pm »
where can i do it? Edit styles-->TOC1 doesn't  work
RoyC
  • Read The Help!
« Reply #3 on: October 02, 2008, 09:30:06 am »
The Contents list should reflect the numbering used in the document sections, so you set your numbering on the section headings. In the product Help, try:
Creating Documents | RTF Documents | Generate RTF Documents | RTF Templates Tab | RTF Style Template Editor | User Defined Section Numbering.
Best Regards, Roy
bla
« Reply #4 on: October 02, 2008, 09:36:42 pm »
thanks! almost done, the only problem is that the field
List override (in the Edit | List and Overrides | Edit List Level menu option) cannot be selected. Why?
RoyC
  • Read The Help!
« Reply #5 on: October 03, 2008, 09:40:43 am »
Not sure - can you provide more details?  Did you create a list item and a list override?
Everything worked smoothly for me. If it isn't working for you, could you send a support request to Sparx Support and explain exactly what steps you took? Use the link at the bottom of this page, and quote this forum entry. Also let the forum know what response you got from Support, and whether it worked.
Thanks.
Best Regards, Roy
