Author Topic: Production/Development versions and change control  (Read 12070 times)
Re: Production/Development versions and change con
« Reply #15 on: October 09, 2007, 03:23:28 am »
Hi Mark,
I have the same experience. If I cut the network, then I get an immediate response that SVN is down and within a moment my model is loaded. I have no idea how to speed up SVN in any respect. I'm the only user on the server and I know that check-out is slow. But status responses are normally not that bad. So for the time being I'm a bit lost.
The log file is not created by default. You would need a special shell script that converts SVN calls into verbose ones. It would not tell you too much anyhow.
Martin Terreni
  • Sorry, I can't write
« Reply #16 on: October 28, 2008, 12:40:49 am »
We are sufering so much from this delayes......
Recursion definition:
