Author Topic: Accessing Repository from Java fails  (Read 3377 times)
Motorpsycho
« on: July 17, 2008, 07:54:29 am »
Hello, i am having trouble accessing my database stored models from JAVA. I can connect to the database and open the repository but access to models, packages or elements only returns "null". See the following code snippet:
DatabaseRepository = new org.sparx.Repository();
DatabaseRepository.OpenFile("eap --- DBType=0;Connect=Provider=MSDASQL.1;Persist Security Info=False;Data Source=eap");
DatabaseRepository.GetLatestUpdate(); // works => Repository is ready and opened
Collection<org.sparx.Package> models = DatabaseRepository.GetModels();  // always returns "null" though there are models existing
org.sparx.Package p = DatabaseRepository.GetPackageByGuid("<guid>"); // returns "null" if <guid> is existing, else throws java.lang.exception
I didn't had this problem with 6.x release of EA. Anyone any idea what i might be missing?
Re: Accessing Repository from Java fails
« Reply #1 on: July 17, 2008, 08:26:22 am »
There was a problem with the early 7.1 builds that caused this.  The latest build should fix your problem.  (And searching would have helped you get this answer sooner...)
« Last Edit: July 17, 2008, 08:26:43 am by simonm »
