Author Topic: Automathic Diagram Class Generation  (Read 2359 times)
Ivan
« on: November 18, 2008, 11:52:47 pm »
I have a java project with all the entities generated. (It was generated with a code generator from a database schema). What I want now is to "generate" a class model in enterprise architect from this java classes. Is that possible??
Thanks in advance,
Ivan
Re: Automathic Diagram Class Generation
« Reply #1 on: November 19, 2008, 10:22:10 am »
Source Code Engineering. Look up reverse engineering.
The first once or twice you try it you might not get the results you expect. Don't panic! Read the directions carefully (again) and follow them explicitly. Once you get the hang of it things will go smoothly.
