Author Topic: issue while openingan existing project  (Read 5058 times)
rafnews
« on: February 04, 2009, 06:56:51 am »
i have 2 PCs at work. i created my project under PC1, however when i try to open it under PC2, EA displays a warning message that it can lock the file.
result : i can not open the project on another computer except on the one used to create the project itself.
What is the problem ?
thanks.
rafnews
Re: issue while openingan existing project
« Reply #1 on: February 04, 2009, 09:15:16 pm »
Oliver F.
    • Karl Storz homepage
« Reply #2 on: February 04, 2009, 11:17:47 pm »
I can not open the screenshot as Rapidshare is blocked from here.
However I can imagine a few things:
- Did you copy the file while EA has opened it on PC1? Try closing EA first on PC1, then copy to PC2
- Did you copy the EA file from PC1 or did you simply a "Save As"? In the latter case it will not work as Save As only creates a shortcut.
Oliver
« Last Edit: February 04, 2009, 11:18:23 pm by ofels »
rafnews
« Reply #3 on: February 04, 2009, 11:27:01 pm »
Hi Olivier,
Basically the EA project is on my external USB HDD. So the project is still the same but i just plug/unplug the HDD and let's go to work.
However, it is not so :-(
Oliver F.
« Reply #4 on: February 05, 2009, 02:32:23 am »
Hi Olivier,
It could be a file system lock on the file by not cleanly unmounting the USB drive. Copy the file to a local disc on PC2 and retry, that would give a clearer picture.
Oliver
rafnews
« Reply #5 on: February 05, 2009, 07:35:05 pm »
Hi Olivier,
thanks for the tip, it works well.
it's crazy that USB does not allows EA to create a ldb file on it.
i do not understand because this problem occurs only under EA.
other softwares do not have such issue.
Oliver F.
« Reply #6 on: February 05, 2009, 11:07:30 pm »
Hi Olivier,
The files created by EA are representations of a database structure. If the USB drive is not cleanly unmounted some important changes might not be written to the file thus EA assumes the file is still open (eg. a transaction is not yet committed, etc.) and refuses to reopen it.
It might be worth a bug report but I believe it is hard to be fixed.
In the tools menu there is an option "Repair EAP file" which might help further.
Oliver
Oliver
« Reply #7 on: February 06, 2009, 12:00:15 am »
I don't think this is an EA bug per se but a limitation of the Jet database driver. Still, some kind of warning (somewhere) in the EA documentation might be in order.
I'll leave it to you folks - or anyone else who has this problem - to send a report to Sparx. I have long since taught myself to close things before popping USB (and other removable storage) devices.
pr1smiley
  • EOD is a Blast!
« Reply #8 on: February 06, 2009, 07:39:13 am »
I have a SimpleTech USB HDD and ALL of my EA projects are contained on the drive with no problem what so ever in opening them
