Author Topic: Hierarchy options on show diagram as element list  (Read 5027 times)
Graham_Moir
« on: July 22, 2009, 09:03:50 pm »
The options "Showed nested package content" and "Show hierarchy" are greyed out and unavailable on any diagram that I show as an element list - does anyone know why this is the case ?   Could it be because the models were created before 7.5 846 was released ?
thanks
ebeb
Re: Hierarchy options on show diagram as element l
« Reply #1 on: July 22, 2009, 09:12:21 pm »
Funny, I was almost about to post the same question. Now that I saw you're posting, I tried it again to confirm - But now it works.  :o
very strange... I know today I tried to see the list view of my requirements model and these two icons were greyed out. I could only see first level elements/packages. But now, it works. I see all elements and packages nested by level.
Graham_Moir
« Reply #2 on: July 22, 2009, 09:36:26 pm »
No such luck for me, I've tried shutting down and restarting EA but the options are still greyed out.
« Reply #3 on: July 23, 2009, 04:08:58 pm »
Because they are only available for the element list showing a package.  When showing a diagram, hierarchy doesn't exist and it doesn't know about packages.
Graham_Moir
« Reply #4 on: July 23, 2009, 06:34:14 pm »
That makes sense Simon,  but in my case even on diagrams that have packages in them the options are not available.
ebeb
« Reply #5 on: July 23, 2009, 06:39:05 pm »
I think simon is right. Maybe I just selected the diagram instead of the package because it is labeled the same.
Graham, in your case it means you have to select the >package< which contains your diagram, not the diagram itself. Only packages work, I can confirm that.
Jan
Graham_Moir
« Reply #6 on: July 23, 2009, 06:48:37 pm »
OK, now I understand, basically these options will never be available when you switch from a diagramatic display to show element list for a diagram, even if the diagram has packages.
You have to select a package in the project browser and then choose show element list from there and the options magically become enabled.
