Author Topic: RTF generator - paper size in virtual documents  (Read 3492 times)
Graham_Moir
« on: October 28, 2009, 05:03:11 am »
Just FYI that after running a few tests I believe I have established that the paper size (A4, legal, letter etc.)  for a virtual document is determined by the last model document defined in the master document.
Re: RTF generator - paper size in virtual document
« Reply #1 on: October 28, 2009, 09:44:48 am »
Now why doesn't that surprise me?
It's like the default diagram for a specific rendering of an element is the diagram with the lowest internal id in which the element is to be found (if things haven't changed).
Thanks for the info Graham,  it will help the rest of us avoid all that investigation...   ::)
« Last Edit: November 02, 2009, 09:28:53 am by PaoloFCantoni »
« Reply #2 on: November 02, 2009, 09:12:40 am »
Corollary:
How do I specify for our organisation that
  • paper size is A4
  • measurement units are cm
  • language is English (UK)
TIA
Graham_Moir
« Reply #3 on: November 02, 2009, 11:27:56 pm »
- Paper size is set via  the File menu Printer Setup option
- From what I can see measurements are in inches or points with no option to change them,  e.g. on Page Layout  (File/Page Layout)
- I can't see any language options in the RTF editor
