Author Topic: How do i set the defualt DataType of ERD to SQL?  (Read 3009 times)
peter king
« on: November 13, 2009, 04:32:27 pm »
Hi Friend,
I use EA 7.5 corp.
I need to set teh default Data Type of the attribuets of the Entitites to MS SQL servers types, how do i do this? i need to do this gloablly so that when i create anther ERD i dont need to rchaneg the type to SQL type?
TY
smendonc
  • I love YaBB 1 Gold!
Re: How do i set the defualt DataType of ERD to SQ
« Reply #1 on: November 13, 2009, 05:04:34 pm »
I've done this by displaying the Code Generation Toolbar and setting the displayed default database option on it.  There is probably a better way to do this but as I do it infrequently its the one I remember.
From the View Menu --> Toolbar --> Code Generation.
Stan.
peter king
« Reply #2 on: November 13, 2009, 07:29:36 pm »
Hi Friend,
I think you'v misunderstood my Q.
When i open a project to create an ERD and drag and Drop a table i want it by defualt to have MS SQL server types.....
When i double click the tbale in the genaral tab in the Database drop down box it will show MS SQL server as defualt.
smendonc
« Reply #3 on: November 14, 2009, 12:54:57 pm »
[edit]When i open a project to create an ERD and drag and Drop a table i want it by defualt to have MS SQL server types.....
[/edit]
This is the behavior that results when the database is set as I described above.  It will work for all new tables created after the setting is changed.
If you already have tables and need to reset them to a different database type, then I think you will need to write a script or use the api.
http://www.sparxsystems.com/uml_tool_guide/uml_modeling_tool_features/codetoolbar.html
Stan.
