Author Topic: Tagged Value as hyperlink  (Read 5991 times)
EA2412
« on: January 05, 2010, 03:13:46 am »
Dear all
is there any possibility to set up a tagged value as hyperlink. The name of the tag should only be a short description but the value should easily be clickable by user to jump to a website for example.
Thanks in advance
Re: Tagged Value as hyperlink
« Reply #1 on: January 05, 2010, 09:22:52 am »
Not as far as I know - but it's a brilliant idea!
Submit a feature request using the links at the bottom of the page!
Reference this topic so that Sparx can see any on-going discussion.
This gets my vote!
Thelonius
  • I think. Therefore I get paid.
« Reply #2 on: January 05, 2010, 09:41:25 am »
Mine too.
Would be useful to be able to provide a link to a local document or folder in the greater repository. As well as a link to Internet content.
Dermot
« Reply #3 on: January 05, 2010, 10:36:35 am »
for local files use the tagged value type - File:
Type=File;
Default=C:\temp;
This does actualy apply for hyperlinks but there appears to be a problem that http:// returns http:/
It is launchable but needs correction - I will pass it on to be checked.
« Reply #4 on: January 05, 2010, 11:28:59 am »
Type=File;
Default=C:\temp;
This does actually apply for hyperlinks but there appears to be a problem that http:// returns http:/
Thanks for that Dermot - useful!   However, I think what the rest of us are after is a generalized hyperlink - that would include diagrams etc..  Is that still possible using this mechanism - with appropriate syntax?
ebeb
« Reply #5 on: January 07, 2010, 07:03:55 pm »
Dermot, Paolo,
that sounds interesting for me, too. Unfortunately, I'm not very experienced in Tagged Values.
Would you please explain how to use that link-feature? This type is not existing. If I use settings/uml/tagged value types to create this type, how can I use it? Is it clickable from within EA or only if I generate a RTF documentation and include the tagged values?
Thanks!
Jan
Dermot
« Reply #6 on: January 08, 2010, 03:01:06 pm »
To use it post creating the tagged value type:
View | Tagged Values (ctrl+Shift+6)
To create the Tagged Value type see: http://www.sparxsystems.com/uml_tool_guide/sdk_for_enterprise_architect/predefinedtaggedvaluetypes.html
- File
ebeb
« Reply #7 on: January 08, 2010, 08:30:23 pm »
- File
May I ask, why the list of TV types are not already existing by default? Why do I have to create these type manually if EA already knows how to deal with them?
I have to disagree. Both local files and hyperlinks work well for me. I tried http://www.google.com which works and by clicking on launch opens the browser.
Nice :)
But, is there a way to add a description what exactly the link is? E.g. if I want to link to other documentation I want to say that link is called "Market Analysis".
Or is TV not the appropriate way to do so?
-Jan
EA2412
« Reply #8 on: January 11, 2010, 09:54:10 pm »
Did you use the file type in TV content? How did you described the detail field?
Thanks in advance
ebeb
« Reply #9 on: January 11, 2010, 10:15:36 pm »
I'm not really sure what you mean...!?
I did the following:
- Create the TV type as explained above.
- open the properties of any element you'd like to add the link
- Go to Tagged Values
- Click on the "new tagged value" button
- Choose File as type (the value is non-editable)
- Once created, you can use the "..." button to navigate to the location or manually enter a file location or http link.
I hope that answers your question...  ::)
-Jan
