Author Topic: Relationship matrix - link type  (Read 5118 times)
Dima
« on: January 22, 2010, 07:26:04 am »
I have simple relationship - <<trace>> between two elements. How can I show this on Relationship Matrix - the link type trace is not there... in fact many link types do not show up in the drop down.
marcelloh
Re: Relationship matrix - link type
« Reply #1 on: January 22, 2010, 07:36:14 am »
I don't know exactly, but if you do the source elemetn and target element types to all, and then select the direction to both... what do you get?
« Reply #2 on: January 22, 2010, 08:34:44 am »
A trace is a stereotyped dependency.
David OD
« Reply #3 on: January 22, 2010, 10:26:19 am »
@Simon: But does the matrix view support the creation of such stereotyped links?  It would be very painful to have to create lots of links and then to have to manually stereotype each of them.  Is there some shortcut that allows stereotyped links to be used in the matrix?
Regards
« Reply #4 on: January 22, 2010, 11:01:08 am »
Trace has been added to the listbox for EA 8.0, but until then (and for any other stereotypes that you may want to add) do the following: Create a profile that defines the stereotype "trace" that extends "Dependency". Give the stereotype class an attribute "_metatype" with an initial value of "Trace". Save the profile. Import the profile in the Resources window. (You may also need to reload your model). All stereotypes with a _metatype attribute set will appear in the matrix listboxes.
« Last Edit: January 22, 2010, 11:03:12 am by KP »
David OD
« Reply #5 on: January 22, 2010, 11:14:06 am »
Brilliant!  :D  We are building a series of profiles and have started using the _metatype attribute, so that should be sorted!
Regards
Dima
« Reply #6 on: January 26, 2010, 06:45:44 am »
Did all this and it worked when I selected "Dependency" in Link Type field of Relationship Matrix. Good advice!
