Author Topic: RTF Numbering has wrong Style!?  (Read 2752 times)
ebeb
« on: January 27, 2010, 12:47:12 am »
RTF headache...again.
I have a rtf template, package as heading 1 and element is heading 2.
Heading 1 is "verdana, 14p", heading 2 is "verdana, 13p".
In the template editor, everything looks good. The "{package.name}" and the number "1." in front of it is both verdana, 14p and for the element as well.
But, here come the problem: After creating the RTF doc, the numbering "1." and also at deeper hierarchy levels are Time New Roman.
This is strange. I checked the Template again:
When I click exactly before the text "{package...}", it says style=heading 1 but font is "Times new roman" which is wrong.  If click on the text, the font is correct. I checked in the menu, and it says its character style "Default Paragraph Style". If try to set Verdana instead of Times, it doesn't work.
What can I do to make the numbering use the same style/font as the heading name?
Thanks!
Coops
Re: RTF Numbering has wrong Style!?
« Reply #1 on: January 28, 2010, 03:18:15 am »
If you're using List numbering have you tried changing the Font in the Edit, Edit List Overides, Edit List Level?
This is what I had to do to get mine to match my heading
I've found outline numbering a total nightmare in EA I have to confess, especially when working with virtual documents
Also I found reading the White Paper "Working with the RTF Generator" helped somewhat althought the documentation around this part of the product is sketchy to say the least.
ebeb
« Reply #2 on: January 28, 2010, 03:34:47 am »
 :D
...works! Perfect, was a bit strage, that the heading numbering is listed as "List Override #03", but using the dialioge, selecting this override, changing the level from 1 to whatever is used, changing the font works!
Great!
Thanks a lot!
