Author Topic: Requirements with the Same Tagged Value  (Read 2847 times)
Randy
« on: April 07, 2010, 01:43:59 am »
Can a list be created of all requirements with the same tagged values?
Dima
Re: Requirements with the Same Tagged Value
« Reply #1 on: April 07, 2010, 05:00:02 am »
Right click the package that contains the requirements, go to Documentation/RTF.., then Element Filters. Then select TagValue - set your tag name and value and it should produce the list.
I just ran a quick test and it seems to be working fine.
Note: you may want to create simple template to get a list in  a table format. Also, make sure you check off Required check box in the filter dialog
Randy
« Reply #2 on: April 07, 2010, 07:10:50 am »
Dima,
Thank you very much!
Randy
« Reply #3 on: April 07, 2010, 04:34:56 pm »
When you are not talking about RTF generation, but just want to see a list you can create a custom search with the SQL option.
The tagged values for elements are stored in the t_objectproperties table.
