Author Topic: DAO 3218 Error  (Read 2376 times)
DAO 3218 Error
« on: June 07, 2010, 12:37:26 pm »
If you get a DAO.Error [3218] message:  "Couldn't Update; currently locked"; the culprit might be an unsaved Access layout change on the affected record.
From what I can see, Access appears to lock the record specification when the layout has been changed and you haven't yet saved (or reverted) the changes; this inhibits EA from updating the record.
NOTE: if you DO get this error, exit EA, fix Access and close it also.  The results, otherwise, appear to be anomalous.
« Last Edit: June 07, 2010, 12:38:36 pm by PaoloFCantoni »
