Author Topic: How Can I layout an activity diagram ?  (Read 2323 times)
cakebunny
« on: June 06, 2010, 02:06:22 pm »
I found that, when I create activity diagram using EA, both layout menu and toolbar shortcut are grey, why ? Can I layout activity diagram ?
Re: How Can I layout an activity diagram ?
« Reply #1 on: June 06, 2010, 04:03:51 pm »
Hi cakebunny,
Somewhere in the documentation, it DOES state that the standard layout algorithm is NOT suitable for Behavioural diagrams - and this is, indeed, the case.
However, you can do some localized layout by selecting the elements you wish and using <context menu>|Layout Selected Elements
I think you can also use the View|Layout Tools layout toolset (again on the selected elements of the diagram).
However, as previously stated, the results aren't very good.
« Last Edit: June 06, 2010, 04:04:25 pm by PaoloFCantoni »
beginner
« Reply #2 on: June 07, 2010, 07:34:31 pm »
The diagram properties have a layout direction (Diagram/Set Layout Style). Chose Down. As Paolo suggests select a number of elements and use the context layout command. It can help with the raw layout in many times. You need to manually rework the result.
b.
