Author Topic: Searching within a diagram  (Read 6258 times)
« on: July 16, 2010, 10:14:14 am »
Ok, its friday, I may be having brain fade, but ...
I have a large diagram, with plenty of entities?
How do I search within the diagram to see if a particular entity is there.
The entities in the diagram do not come from the associated package, and are indeed scattered across many packages.
I thought ctrl-F would be a good idea, but it runs across the entire repository, and seems to have no (simple) way to limit it to the open diagram.
Re: Searching within a diagram
« Reply #1 on: July 16, 2010, 10:21:57 am »
Find the item in the browser then use "Find in Diagrams".  If the target diagram is on the list it will find where in the diagram the item is...
« Reply #2 on: July 16, 2010, 10:39:12 am »
Now why did I expect that would be the answer.
Since the resultant list of diagrams is unsorted I had hoped to simply to text search the diagram and have the entity highlighted.
¡Así es la vida!
« Reply #3 on: July 16, 2010, 11:14:17 am »
Show the diagram in the Element List (Right click | Switch to List View)
Sort and group elements however you want.
« Last Edit: July 16, 2010, 11:14:33 am by simonm »
« Reply #4 on: July 16, 2010, 11:21:06 am »
Add it to your list of resizable, sortable by column dialogs!
Sic vita est!
« Reply #5 on: July 16, 2010, 11:45:07 am »
Thankyou
Aaron B
« Reply #6 on: July 16, 2010, 12:17:12 pm »
RE: your original question - If you right-click on the element in the Project Browser, there is a "Locate in Current Diagram" menu item.  If the element is not on the current diagram, this item is greyed-out.  HTH.
« Reply #7 on: July 16, 2010, 01:53:10 pm »
